Josh's First Year Thread
* * * * * 1 votes First Year 3D Games Art Design 2D Concept Maya
120 replies to this topic
#31
Joshua Crew
Joshua Crew
    Junior Member
  • 92 posts
Research and development, do a few renders of you shark with the wrinkles around the eye lightly defined, slightly heavier, even heavier and so on. Just as a way of solidifying your theory of making them more pronounced so they show up with the darker textures. This will just help you to get the best possible outcome with you final render. You can then compare the renders to real reference to see which is the most realistic. :)
Ah yeh... that definitely seems like something I'll be doing, thank you for the great suggestions btw :)
#32
Samuel_lee
Samuel_lee
    3D Modeler
  • 63 posts
Yeah it will most definitely help you out with a lot of stuff. :D You're more than welcome mate!
#33
Joshua Crew
Joshua Crew
    Junior Member
  • 92 posts
Adding some finer details ready for bake over my low mesh. I decided I wasn't happy with the artifacts left over from Dynamesh... I know the features/wrinkles are exaggerated, but they'll appear toned down with a dark material over the top. I also wanted to go for more of a characterized look.
Attached File  shak.PNG   376.96KB   0 downloads
  • Soulss likes this
#34
Molotov
Molotov
    GamesArt~Level5
  • 154 posts
Hi Josh, nice details you got here, however the gills are a bit too small, since I'm doing great white shark as well, I've been doing some researches and I've noticed that his gills are all the way down from his eye level to the fin..
great-white-shark-on-blue.jpg?bc=white&h
Attaching an image, so you'd understand me properly :D
Keep it up :)
#35
floorpeas
floorpeas
    Games FX Artist
  • 1673 posts
  • Xbox 360 Gamer Tag:floorpeas
  • Company: Creative Assembly
You need to re-look the mouth area. You have made your mouth quite humanistic, giving it the lips. If you look at the above image, the nose is streamlined with the body, and the mouth comes right back behind the eye. Their jaws also open into an almost circular shape when open as the skin stretches around the jaw.
#36
Joshua Crew
Joshua Crew
    Junior Member
  • 92 posts
Compositional study using the golden spiral and framing for the art skills brief
Attached File  Clouds.jpg   52.11KB   0 downloads
  • Doxturtle, Lluis Cavalcanti, Tom_mccall and 1 other like this
#37
owenm
owenm
    Member
  • 206 posts
i want that as a phone wallpaper
#38
Joshua Crew
Joshua Crew
    Junior Member
  • 92 posts
Just threw some quick materials on to see how it looks so far. Still have to re-model the pedals and handle-bars. Also not happy with the deisgn of the rider-interface above the front wheel, but it's getting there!
Attached File  Capture.JPG   59.67KB   0 downloads
  • Molotov likes this
#39
owenm
owenm
    Member
  • 206 posts
shader looks a bit plasticy right now id turn the roughness down also get an image in as an hdri so we can see the reflectsions better
Edited by owenm, 28 November 2016 - 04:00 PM.
#40
Joshua Crew
Joshua Crew
    Junior Member
  • 92 posts
I had a play around with some of the materials, added a lil bit of quick enviro lighting and re-modelled a load of details! I think I'm calling this done, now to get renders sorted
Attached File  mat.jpg   80.47KB   0 downloads
  • LisieMae and elysper like this
#41
elysper
elysper
    Level 5 Student
  • 218 posts
Your tron looks so freaking good! *.*
  • Joshua Crew likes this
#42
LisieMae
LisieMae
    Lisa Mae
  • 194 posts
Dude that looks freakin' great- your proportions are spot on as far as I can tell. You should be super proud  :)
  • elysper and Joshua Crew like this
#43
Joshua Crew
Joshua Crew
    Junior Member
  • 92 posts
Thank you so much! :)
#44
Joshua Crew
Joshua Crew
    Junior Member
  • 92 posts
After finishing the unwrapping of my shark I wanted to bake normals from my high poly! The normals came out really nicely, but couldn't figure out Maya so I had a play around in Substance!
Attached File  shark.jpg   31.67KB   0 downloads
  • Evanish and Luuke like this
#45
Joshua Crew
Joshua Crew
    Junior Member
  • 92 posts
Aaaaand I finally got a displacement map working in Arnold renderer! Wooooo
Attached File  shark.jpg   48.18KB   1 downloads
  • Jason_Costa and elysper like this
0 members, 0 guests, 0 anonymous users
