Chris Pereira Post-Uni Thread
13 replies to this topic
chrispereira
chrispereira
    Uber Poster
  • 1460 posts
Well since University is over, I get to werk on whatever I want (especially since i have no job) :( Crit as always highly appreciated and wanted :)
At the moment, I'm working on two projects, a character piece based on this piece (Xuan Xe) -
https://www.artstati...m/artwork/4qQZW
xuan-ke-.jpg?1487776780
Second piece being an environment piece, I wanted to go for a quite Witcher 3 detail/realism level, the idea is it will be a florist/witch house with lots of different cool potions/flours/props. Here's some influence i gathered, still doing some research on this project!
This piece is my main source of inspiration:
sergio-raposo-fernandez-final.jpg?147617
I want to be warm, magical and not scary at all which most witch houses look like nowadays in movies and games. Also very messy and clutter with tons of individual props!
This is the board i'm using for influence:
https://uk.pinterest...900/la-alchemy/
Edited by chrispereira, 08 June 2017 - 02:15 AM.
  • Jason_Costa and Soulss like this
chrispereira
chrispereira
    Uber Poster
  • 1460 posts
Update on the head sculpt:
chrispereira
chrispereira
    Uber Poster
  • 1460 posts
Update on le body, crit really wanted :o
chrispereira
chrispereira
    Uber Poster
  • 1460 posts
Prevising in Marmoset -
  • pixel and PandaLog like this
LittleClaude
LittleClaude
    Uber Poster
  • 8420 posts
  • Xbox 360 Gamer Tag:LittleClaude
Hi
You had a really nice final major project, if I where you I would focus on a few more environment pieces. 2X buildings 1X corner room scene and then your portfolio will start taking shape. Then once your working in the games industry then start to develop your character art outside of work.
nice Elf BTW :)
Edited by LittleClaude, 11 June 2017 - 08:00 AM.
Elm
Elm
    2D Scrub
  • 180 posts
  • Gender:Not Telling
Other than the illustration, what other references are you using? The body feels a little unnatural to me, like a combination of more than one body type and the face is on the masculine side for this elf in particular. From looking at the illustration, that doesn't look like the right kind of nose, the cheeks don't seem to match, the ears straighter and not as thinly tapered off as you have done in the sculpt. My personal opinion, is that the eyebrow ridge should be higher, but that may be more a stylisation concern, as I think when the eyes are open they would look too close to the brows in comparison to the concept art.I also don't think you should have cut into the eyelids so early.
Obviously take what I say with a grain of salt, as my anatomy knowledge is lackluster. But it's also something I want to improve on.
Are you going to put the elf into the scene? Curious to see how you set it up.
  • Chlowaii likes this
chrispereira
chrispereira
    Uber Poster
  • 1460 posts
Hi
nice Elf BTW :)
Yes Neil, I do quite agree, I was doing the character more for fun (or long term piece, going to put it down for now). I've started some shader tests with the Witcher 3 inspired piece already, will be my next big enviro :D
oh I agree, really appreciate that detail feedback man, my anatomy game is weak! Also i plan to put it posing and sitting like the reference with the chair and some surrounding props..
#8
chrispereira
chrispereira
    Uber Poster
  • 1460 posts
Not posting much since I haven't had much time with my prepartions to move abroad but heres some doodles I did when i got anytime :c
#9
chrispereira
chrispereira
    Uber Poster
  • 1460 posts
I've mostly been drawing in my free time, lazing away from any 3d personal work. Some drawings are drawn from reference and some aren't.
24824641_10213162556892083_1676946660_n.23804719_10213039760062239_1880277350_n.24172257_10213088434159061_99898003_n.pn24550222_10213137012293484_297000956_n.j24899013_10213161545946810_390571968_n.j
#10
chrispereira
chrispereira
    Uber Poster
  • 1460 posts
#11
DigitalSalmon
DigitalSalmon
    Alumni
  • 1256 posts
You go over the same lines lots of times, making them darker and thicker, but also making them less clear to read - You might benefit from slowing down a bit.
Also; Try using tracing paper over the top to trace out your lines with just a single, thin line - then you can objectively critique your form and proportion.
There's lots of potential; just need to be more deliberate with your line work. Try drawing by only using a pencil very very lightly, then inking over the top when you're happy.
Best of luck,
  • chrispereira likes this
#12
Kayta
Kayta
    Concept noodler
  • 110 posts
I'd say when you shade anything make sure you know where your light source is coming from, maybe draw some arrows. At the moment it looks like you're using shading as a device to define certain areas better but it ends up being a bit confused because there's no obvious light source.
Maybe go to some life drawing classes not just to help your anatomy and line confidence but also because they often have a nice lighting setup and you can see how the human form acts under light better.
You can usually use 2 or 3 values to give a basic read of the subject. I don't know if you're practicing drawing to eventually lead onto painting but I found that it helped a lot to start seeing my drawings as blocks of shape rather than as lines if that's your end goal. Keep using reference whenever you draw, even if its for small bits and pieces.
If you look at this process for a portrait by Nathan Fowkes, you can see in the second stage he just has two main values when he's blocking in the face yet because the shapes are very clearly defined it gives a good read.
I know this example is very different to the way you're working right now but I've found it's always good to look at a lot of different examples of how people successfully portray the same subject and see what you can learn from it :)
Hope you find this helpful, looking forward to seeing more stuff on this thread :D
  • chrispereira and TheChunkyChin like this
#13
chrispereira
chrispereira
    Uber Poster
  • 1460 posts
Both of your points are very valid. Especially agree with the shading and dark thick lines :) I will work on those thank you!
  • Kayta likes this
#14
Moid
Moid
    It was the night of the demon
  • 15353 posts
  • Company: University of Hertfordshire
Chris - are you getting all the emails I've been sending out about games art jobs? There's been quite a few in the past three months.
Anything by Nathan Fowkes is amazing... I really love his landscape images.
  • PandaLog likes this
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
