A.R.Ch's Work Thread level 5
22 replies to this topic
A.R.Ch
A.R.Ch
    Member
  • 126 posts
~Hello!~
Here I post my work from this year's projects , my own and some stuff I do during the holidays.
I am up to any criticism and improvements. I do both digital and 3D work so it might be a mixture but I will try to keep everything in order xD
Usually I post both finalised pieces or WIP to record my progress and be able to correct my mistakes~
  • TheChunkyChin likes this
A.R.Ch
A.R.Ch
    Member
  • 126 posts
~Something I did during the holiday~
  • Lluis Cavalcanti, nerdsharpie, Oliver Hopley and 3 others like this
A.R.Ch
A.R.Ch
    Member
  • 126 posts
Recently finished my frozen axe concept art and I really enjoyed designing weapons~
  • nerdsharpie, Maria Tsianti and Mr.Jak like this
A.R.Ch
A.R.Ch
    Member
  • 126 posts
WIP ~ first time sculpting a male body! It's not finished at all and this is only the base as I need to fix lots of anatomical errors.
yi9Kwsxl.jpg?1
  • nerdsharpie, elliotthc and Maria Tsianti like this
elliotthc
elliotthc
    Junior Member
  • 81 posts
Really good start so far, it's hard to work out proportions without seeing the full thing. I feel like you could do with defining the ribs more and separating the traps from the other neck muscles more maybe. Maybe try and define the muscle groups and forms before the smaller forms. looks good though!
A.R.Ch
A.R.Ch
    Member
  • 126 posts
Thanks for the advice!! Atm I am trying to define the muscles you've mentioned!
Edited by A.R.Ch, 08 September 2017 - 03:34 PM.
  • elliotthc likes this
elliotthc
elliotthc
    Junior Member
  • 81 posts
okay, so looking at the model, I feel like you've gone into the smaller forms too quickly. what ref are you using? the back muscles seem quite lacking with the shoulders being too defined as a separate mass. The shoulders should slope down the arm rather than cut into the arm. I'd recommend working in a low subdiv to block out the forms better, rough for now. the ribs really define the form of the torso so it's important to factor them in. The best way i can describe making the neck is to imagine it's a cylinder on the torso. As currently the neck flows into the shoulders and torso too much making it seem more like a cloth rather than a separate muscle group. The forearms and shins look great. However the bicep should continue up under the arm. somewhat covered by the peck. If you put your arm out tensed and follow the flow of your bicep you can get a good idea of how it weaves into the shoulder region. Looking at the obliques/side of the torso muscles. I think you need to block the overall form in before worrying about the individual muscles. I've linked a picture below which shows off the obliques very well. Looking at the half of the body the bum cheeks are an unusual shape. I personally hate sculpting the bum as it's hard to judge the forms. However i've added an image below that might be able to show you what i mean. The bum should somewhat pinch at the sides. I hope this helps.
oblique-workouts.jpgbutt-workouts-for-men-1024x1024.jpgmale_back_study_by_kawiku-d8dwvzz.png
  • nerdsharpie, Giorgio Pennisi, TheChunkyChin and 1 other like this
#8
A.R.Ch
A.R.Ch
    Member
  • 126 posts
Thanks for your feedback and references! I am using muscle diagrams for my references and some real life models example. I've tried to emphasise the neck and make the abs slightly unequal as you pointed out that it looks too geometric and "cloth like" and I increased the back muscles~
#9
A.R.Ch
A.R.Ch
    Member
  • 126 posts
Finished the base of hands! Still lots to fix~
And some concept sketches I've done ~ I know some anatomical parts are exaggerated but I wanted to play a bit with the dynamics of the body~~
  • Giorgio Pennisi and JWallace3D like this
#10
A.R.Ch
A.R.Ch
    Member
  • 126 posts
Decided to do some quick experiments with lighting and some dark colour schemes~
  • Oliver Hopley, Giorgio Pennisi, elliotthc and 1 other like this
#11
A.R.Ch
A.R.Ch
    Member
  • 126 posts
Started sketching a creature and I'm pretty sure I will turn it into a 3D sculpt ~
Also a quick study ~ I really wanted to use some chalky brushes ~
  • Oliver Hopley, Giorgio Pennisi and JWallace3D like this
#12
A.R.Ch
A.R.Ch
    Member
  • 126 posts
Never got to post this ~
  • Oliver Hopley and Giorgio Pennisi like this
#13
A.R.Ch
A.R.Ch
    Member
  • 126 posts
Finished the base ~ need to create its topology then rig it ~
I'm not doing lots of details as I wanted to get the form and get used to the male anatomy ~ I am going to do separate studies for it.
#14
Chlowaii
Chlowaii
    Lambie at your service!
  • 554 posts
Hey, looking nice so far
I know you said you weren't going to go into detail, but I'd have another look at the head, particularly the placement of those ears. They're pretty high up and make the head look a bit strange. Would be a shame to topologise and rig the character to find later that there is a small anatomical error.
Here's what I am on about:
  • A.R.Ch likes this
#15
A.R.Ch
A.R.Ch
    Member
  • 126 posts
Ahh thank you so much for pointing that out!! Yh, wouldn't want to finish the topology and then I realise is wrong xD Thanks again
  • Chlowaii likes this
3 user(s) are reading this topic
0 members, 3 guests, 0 anonymous users
