JJ ~ Level 5 Work Thread (Jaratchai Chongjaroenjai)
6 replies to this topic
Jaratcho
Jaratcho
    Junior Member
  • 64 posts
Finally getting back to 3Dhit :D
Here are some work I've done for my concept art brief. We have to reinvent two characters and an environment from the movie "Metropolis".  Any criticism or suggestion is appreciated! Thank you :D
My first character "Rotwang" the scientist, reinvented as a pirate.
The robot "Maschinenmensch" reinvented in Japanese clothing inspired by the Geishas in Ghost in the Shell.
The city of Metropolis reinvented, inspired by the Rainforest District from Zootopia.
Hope you guys enjoy this thread!
Edited by Jaratcho, 23 October 2017 - 02:28 AM.
  • Molotov, Lluis Cavalcanti, Mitt and 12 others like this
Lluis Cavalcanti
Lluis Cavalcanti
    Senior Member
  • 639 posts
Really liking those environments
  • Jaratcho and TheChunkyChin like this
Benstef12
Benstef12
    Level 5 Games Art
  • 55 posts
Really nice work here. I like the Metropolis concept!
You could emphasise that the buildings are carved out of trees, but other than that you have some good work here! :D
Jaratcho
Jaratcho
    Junior Member
  • 64 posts
My Matte painting so far. I still need to replace the main focal point and fix the lighting on the foreground. Any crit or suggestions welcomed!cJNdqbx.gif
Here's another character I worked on for my concept art brief : A companion robot, inspired by Wall-E and Eve :D
Edited by Jaratcho, 01 November 2017 - 02:45 AM.
  • joe lynch, JWallace3D, TheChunkyChin and 6 others like this
Eddy Idriss
Eddy Idriss
    Dayman (Fighter of the Nightman)
  • 487 posts
  • Company: Double Negative
As you are aware with the lighting direction in the matte painting, your foreground shadows are lit from the front where as the back and mid-ground are lit from screen left. If you compare the direction of the shadows on the foreground posts against the bright areas of the sky. A quick fix rather than changing the foreground to work is in Nuke lift the foreground shadows to match the same luminance as the snow. You can do this with an Add node or a grade node. Then with a rotopaint you can do a max reveal with a low opacity and that should remove the darker shadow areas for you to then fudge into place. Its not 100% accurate but it saves you time rather than having to redo your composition. Here is an example:
You can also clone stamp problematic areas.
  • Jaratcho and TigressTu like this
Jaratcho
Jaratcho
    Junior Member
  • 64 posts
Thank you! I will put it into Nuke and see what I can do with that.
Jaratcho
Jaratcho
    Junior Member
  • 64 posts
Update on the Random42 - Hepatitis B brief and my ecorche for the Self Portrait brief :D  Any crit is appreciated!
Password : random
  • joe lynch, Benstef12, Cloudyko and 3 others like this
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
